1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NFS performance problems on vxWorks
To: Dirk Zimoch <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Thu, 11 Nov 2004 10:25:27 -0600
Dirk,
Dirk Zimoch wrote:
our vxWorks IOCs mount their boot directory, auto-save-and-restore directory and data aquisition directory via NFS.
Now, I noticed a very poor performance on several IOCs. Test
When only vxWorks is running but not EPICS, it seems to be ok. If an empty EPICS (no records) is running, there few errors. The problem does not depend on the EPICS version (I tried 3.13.2 and 3.13.9). The idle time of the ioc is about 80%.
The NFS protocol version supported by vxWorks uses UDP packets for data transfer, and is not as efficient at handling dropped packets as TCP is. In your case, I suspect that your IOCs are dropping input packets from the network, which causes the 5 second NFS delays.
Since your IOC has lots of idle time available, you should be able to resolve this by just increasing the size of the network input buffer pool, which is usually one of the parameters in the vxWorks END configuration string - have a look in your sysEnd.c file [or wherever the xxxEndLoad() routine is called in your BSP] and increase the number of read buffers.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
Re: NFS performance problems on vxWorks Till Straumann
NFS performance problems on vxWorks Dirk Zimoch
Prev: NFS performance problems on vxWorks Dirk Zimoch
Next: Re: NFS performance problems on vxWorks Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
