-----Original Message-----
Sent: Fri 11/12/2004 10:43 AM
To: Dirk Zimoch
Cc: EPICS tech-talk
Subject: Re: NFS performance problems on vxWorks
Hi Dirk,
Dirk Zimoch wrote:
> It seems, our BSP is not using the End driver. I don't have a sysEnd.c
> file. I have a configNet.h file, that defines a network config string:
You probably are using and end driver, it just doesn't use the setup I
described. Your load string defines the parameter you need to modify.
Change this:
> #define DEC_LOAD_STRING "0xfe020000:0x0:0x12:0x12:-1:-1:-1:0:0x80000000"
into this:
#define DEC_LOAD_STRING "0xfe020000:0x0:0x12:0x12:128:-1:-1:0:0x80000000"
The individual parameters are described in the vxWorks documentation for
the dec21x40End library (section 1), which explains that the default vaue
for <nrds> is 32; increasing that should significantly improve your NFS
performance on a busy network.
We have also noticed the improvement here at the SNS by increasing the endPool resources as well.
Note that in recent versions of the driver (provided with WRS patches or a
recent version of Tornado), there are several more optional parameters
that can control the network MII phy interface. These may not be
documented other than in the source code.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night. That was really cool. - Caro
Re: NFS performance problems on vxWorks Andrew Johnson
calc and calcout records in EPICS 3.14.6 Geoff Savage
<2004>
2025
2026
counting semaphore for 3.14.x Kate Feng
<2004>
2025
2026
