1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gateway error message
To: Jeff Hill <[email protected]>
Cc: [email protected], [email protected], Ken Evans <[email protected]>
Date: Tue, 16 Nov 2004 13:53:47 +0100
Jeff Hill wrote:
Hi Joan,
Would a misbehaving client(s) cause this behavior?
Yes, it appears that the client is attempting to convert “User Request PS OFF” to a DBR_TIME_FLOAT. The client is receiving one of either ECA_NOCONVERT or ECA_GETFAIL in response to its request.
The “ server tool changed bounds on request” text in the message isn’t accurate. I will attend to that. You might see many, many messages if the client was subscribed with an inappropriate type to a periodically changing channel. Perhaps adding an entry in the log for a routine situation like a conversion failure is only a nuisance. I think that the original concern was that the type used internally by the server plug-in (in this case a string inside the gateway) would unknown for fault isolation purposes otherwise. What do you think?
Jeff
-----Original Message-----
*From:* [email protected] [mailto:[email protected]]
*Sent:* Tuesday, October 26, 2004 1:10 PM
*To:* [email protected]
*Subject:* gateway error message
We installed a new linux R3.14.6 gateway yesterday and in less than 24 hours
the log file filled up with ~48k lines of error messages, all referring
to the same pv. The error message is:
Oct 26 08:11:22 !!! Errlog message received (message is above)
----------dump This=0xa0a9c28---------
dimension=0 app-type=16 Scalar
prim-type=aitString(aitEnumString)
this=0xa0a9c28 string=0x4041eac8<User Request PS OFF>, length=19, buf length=20, type=Allocated
ref-count=1
total-bytes=64, data-size=28, element-count=1
LocalDataFormat
filename="../../../../src/cas/generic/casStrmClient.cc" line number=607
server tool changed bounds on request - get notify with PV=TMMSTATUS type=16 count=1
The addresses following "dump This", and "string=" change with each message.
The pv in question, TMMSTATUS, is a string out record, written to very seldom
by a sequencer code. We don't know anything at this time about clients using this record.
Would a misbehaving client(s) cause this behavior? Is it really an error? Is the client
getting its data in spite of the message? If data is being delivered, it might be much
harder to find the "bad" client?
Or am I way off track?
Has anyone else seen this?
Actually it seems, we are seeing exactly the same problem here at BESSY.
I'd just like to add some observations we made.
1. Everything is running fine for quite a while (days, weeks or even more).
"Suddenly" clients accessing PVs through this gatweway get the following error:
CA.Client.Diagnostic..............................................
Message: "Could not perform a database value get for that channel"
Severity: "Warning" Context: "detected by: gwc1c.acc.bessy.de:5064 for: server tool changed bounds on request - with request chan=H1PT:stat2 op=0 data type=DBR_STS_DOUBLE count=1"
The operation timed out: H1PT:stat2..............................
At the same time the above mentioned errormessage appears in the gateway log.
2. We could just see this with PVs that are actually bi-records (enum...)
3. A restart of the gateway makes the problem disappear - for a while.
4. We have no idea what causes the problem to appear.
My guess would be, that the gateway is the "misbehaving client", but I don't know under what circumstances the problems can be reproduced.
We don't really know what to look for, but we could give more diagnostic output on request.
The gateway-output on a kill -USR1 looks perfectly healthy...
Thomas
______________________________________________________________________
/homas.Birke @ bessy.de
BESSY                                           Tel: +49 30 6392 4934
Albert Einstein Straße 15                       Fax: +49 30 6392 4859
12489 Berlin
Germany
RE: gateway error message Jeff Hill
Prev: RE: calc and calcout records in EPICS 3.14.6 Williams Jr, Ernest L.
Next: RE: linux ioc console Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: gateway error message Jeff Hill
Next: [Fwd: JCA 2.1.4 and CAJ released!] Gasper Pajor
