1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: gateway error message
To: <[email protected]>, <[email protected]>
Cc: "'Ralph Lange'" <[email protected]>, "Ken Evans" <[email protected]>
Date: Tue, 26 Oct 2004 13:58:43 -0600
Hi Joan,
> Would a misbehaving client(s) cause this behavior?
Yes, it appears that the client is attempting to convert “User Request PS OFF” to a DBR_TIME_FLOAT. The client is receiving one of either ECA_NOCONVERT or ECA_GETFAIL in response to its request.
Theserver tool changed bounds on request” text in the message isn’t accurate. I will attend to that. You might see many, many messages if the client was subscribed with an inappropriate type to a periodically changing channel. Perhaps adding an entry in the log for a routine situation like a conversion failure is only a nuisance. I think that the original concern was that the type used internally by the server plug-in (in this case a string inside the gateway) would unknown for fault isolation purposes otherwise. What do you think?
Jeff
-----Original Message-----
Sent:
Tuesday, October 26, 2004 1:10 PM
To: [email protected]
Subject: gateway error message
We installed a new linux R3.14.6 gateway yesterday and in less than 24 hours
the log file filled up with ~48k lines of error messages, all referring
to the same pv. The error message is:
Oct 26 08:11:22 !!! Errlog message received (message is above)
----------dump This=0xa0a9c28---------
 dimension=0 app-type=16 Scalar
 prim-type=aitString(aitEnumString)
this=0xa0a9c28 string=0x4041eac8<User Request PS OFF>, length=19, buf length=20, type=Allocated
 ref-count=1
 total-bytes=64, data-size=28, element-count=1
 LocalDataFormat
filename="../../../../src/cas/generic/casStrmClient.cc" line number=607
server tool changed bounds on request - get notify with PV=TMMSTATUS type=16 count=1
The addresses following "dump This", and "string=" change with each message.
The pv in question, TMMSTATUS, is a string out record, written to very seldom
by a sequencer code. We don't know anything at this time about clients using this record.
Would a misbehaving client(s) cause this behavior? Is it really an error? Is the client
getting its data in spite of the message?  If data is being delivered, it might be much
harder to find the "bad" client?
Or am I way off track?
Has anyone else seen this?
Thanks for your help.
Joan
Joan Sage                    Telephone: (757) 269-7008
Email: [email protected]               Fax: (757) 269-7049
Computer Scientist, Accelerator Controls Group
TJNAF, MS 85, 12000 Jefferson Ave. Newport News VA 23606
Re: gateway error message Thomas Birke
gateway error message Joan Sage
Prev: gateway error message Joan Sage
Next: Re: Building RTEMS on Solaris Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: gateway error message Thomas Birke
