wtw00992 wrote:
Greetings from L.I.
We currently run our Slow Controls for the STAR experiment at BNL using
EPICS and VxWorks running on a Solaris.
We run solaris 8, gnumake 3.79.1, gcc 2.95.3, perl 5.005.
Last week we began our build of RTEMS and ran into several problems
right from the start. We were trying to build for a target mvme167.
During the course of this we looked at many list serv archives, and I
failed to see where anyone had had an issue with these
target/platforms. I did see an email form Eric Norum regarding folks
building for a mvme167 using RTEMS on a Linux... and it got me thinking
that maybe no one is trying this. (Either that or its easy and we are
just klutzes???)
Has any one tried building RTEMS for Solaris with this target? If so I
would be interested in hearing from you.
For the record we tried the following:
We followed the tutorial http://www.aps.anl.gov/epics/base/RTEMS/tutorial/
The first trouble we had was with the "Get and build the development
tools". We simply couldnt get the RTEMS patches for gcc3.2.3 from the
OAR site to work when we applied them on the solaris. We ignored this
finally but clearly the RTEMS build failed with out the right tools. We
eventually tried building the gcc tools on a Mac OSX and a Linux machine
and they work ... so we took the patched files we created there and
tried to compile those. Still when we tried to build RTEMS itself it
stil failed. And despite some very powerfull wishful thinking our
attempts to get EPICS to compile with this failed as well :-)
We also tried to ftp the latest version of the tools from the RTEMS
site. Still the RTEMS build problems persisted.
I'm checking to confirm this, but I suspect that the problem will go away if
you use GNU make rather than the SUN make. Just set the MAKE environment
variable to gmake and try running the getAndBuild script again.
Eric Norum [email protected]
Advanced Photon Source Phone: (630) 252-4793
Argonne National Laboratory
- Building RTEMS on Solaris wtw00992
RE: gateway error message Jeff Hill
[Fwd: JCA 2.1.4 and CAJ released!] Gasper Pajor
<2004>
2025
2026
gateway error message Joan Sage
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
