>>>>> "Andrew" == Andrew Johnson <[email protected]> writes:
> There are also problems with a 68K C++ compiler built from these sources;
> in that case the issue is related to passing bool variables as arguments
> to functions or member functions - again I haven't chased the detail.
Plus a problem with NULL pointers being treated wrong in expressions
(after setting a pointer to NULL, comparing it to NULL in an expression
would yield a FALSE).
Afaik this problem is appeared only in the 68k version of the original
Tornado 2.0.2 compiler and was fixed with a later patch. Anyway:
compilers built from the sources available at SNS are not showing this
bug. (That's why we rebuilt even our HP-UX based compiler from the SNS
sources.)
Seems you have to choose which bugs you prefer ...
Ralph
- calc and calcout records in EPICS 3.14.6 Geoff Savage
- Re: calc and calcout records in EPICS 3.14.6 Dirk Zimoch
- Re: calc and calcout records in EPICS 3.14.6 Andrew Johnson
RE: Has Anyone Built CMLog with Recent Releases (R3.14.x) of EPICS? Allison, Stephanie
RE: calc and calcout records in EPICS 3.14.6 Mark Rivers
<2004>
2025
2026
<2004>
2025
2026
