Andrew and Ralph,
We've been using the SNS versions of PPC and 68K compilers without being
aware of the bugs that Andrew mentioned. Are these documented somewhere
on the Web?
> > There are also problems with a 68K C++ compiler built from these
> sources;
> > in that case the issue is related to passing bool variables as
> arguments
> > to functions or member functions - again I haven't chased the
detail.
> Plus a problem with NULL pointers being treated wrong in expressions
> (after setting a pointer to NULL, comparing it to NULL in an
expression
> would yield a FALSE).
> Afaik this problem is appeared only in the 68k version of the original
> Tornado 2.0.2 compiler and was fixed with a later patch. Anyway:
> compilers built from the sources available at SNS are not showing this
> bug. (That's why we rebuilt even our HP-UX based compiler from the SNS
> sources.)
- Re: calc and calcout records in EPICS 3.14.6 Ronald L. Sluiter
Re: calc and calcout records in EPICS 3.14.6 Ralph Lange
RE: calc and calcout records in EPICS 3.14.6 Thompson, David H.
<2004>
2025
2026
RE: calc and calcout records in EPICS 3.14.6 Williams Jr, Ernest L.
<2004>
2025
2026
