Subject: |
Re: Problem building epics base-3.14.6 with recent gcc on linux |
Robert Soliday <[email protected]> |
To: |
tech-talk <[email protected]> |
Date: |
Thu, 18 Nov 2004 10:12:14 -0600 |
I do not believe it has anything to do with your compiler. It appears
that you do not have the readline package installed. You can still get
EPICS Base to compile without it if you edit
base/configure/os/CONFIG_SITE.Common.linux-x86 and comment out the last
line where it sets COMMANDLINE_LIBRARY = READLINE
--Bob Soliday
Chip Piller wrote:
I've tried to build epics base-3.14.6 on linux, results are:
gcc 3.3.2: Success.
gcc 3.3.4: Failed for both 3.14.6 and latest CVS.
gcc 3.4.2: Failed for both 3.14.6 and latest CVS.
Any info/suggestions for using recent gcc?
Chip Piller
Output from failed build:
-I../../../include ../../../src/libCom/osi/os/default/epicsReadline.c
../../../src/libCom/osi/os/default/epicsReadline.c:77:31:
readline/readline.h: No such file or directory
../../../src/libCom/osi/os/default/epicsReadline.c:78:30:
readline/history.h: No such file or directory
../../../src/libCom/osi/os/default/epicsReadline.c: In function
`epicsReadlineBegin':
../../../src/libCom/osi/os/default/epicsReadline.c:102: warning:
implicit declaration of function `stifle_history'
../../../src/libCom/osi/os/default/epicsReadline.c:103: warning:
implicit declaration of function `rl_bind_key'
../../../src/libCom/osi/os/default/epicsReadline.c:103: error:
`rl_insert' undeclared (first use in this function)
../../../src/libCom/osi/os/default/epicsReadline.c:103: error: (Each
undeclared identifier is reported only once
../../../src/libCom/osi/os/default/epicsReadline.c:103: error: for each
function it appears in.)
`epicsReadline':../../../src/libCom/osi/os/default/epicsReadline.c:125:
warning: implicit declaration of function `readline'
../../../src/libCom/osi/os/default/epicsReadline.c:125: warning:
assignment makes pointer from integer without a cast
../../../src/libCom/osi/os/default/epicsReadline.c:163: warning:
implicit declaration of function `add_history'
make[3]: *** [epicsReadline.o] Error 1
make[3]: Leaving directory
`/home/piller/epics/base-3.14.6/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/piller/epics/base-3.14.6/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/piller/epics/base-3.14.6/src'
make: *** [src.install] Error 2
piller@piller64 ~/epics/base-3.14.6 $
- Re: Problem building epics base-3.14.6 with recent gcc on linux Chip Piller
- Problem building epics base-3.14.6 with recent gcc on linux Chip Piller
<2004>
2025
2026
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
