Subject: |
Re: Problem building epics base-3.14.6 with recent gcc on linux |
Chip Piller <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 18 Nov 2004 11:30:44 -0500 |
OK, I tried your suggestion to comment out the last line in
base/configure/os/CONFIG_SITE.Common.linux-x86
and now...success! (using gcc 3.3.4).
I did not know about the readline package requirement, where do I find
this?
What I did was download epics base and also latest CVS from the
aps.anl.gov/epics site, tar xzvf the file, read the build instructions
in documentation/README.1st.
I have gcc and g++ in my path, I set the EPICS_HOST_ARCH environment
variable, I ran command "make clean uninstall" followed by "make".
It is interesting that the build succeeded without the readline package
using earlier gcc.
Chip Piller
Robert Soliday wrote:
I do not believe it has anything to do with your compiler. It appears
that you do not have the readline package installed. You can still get
EPICS Base to compile without it if you edit
base/configure/os/CONFIG_SITE.Common.linux-x86 and comment out the last
line where it sets COMMANDLINE_LIBRARY = READLINE
--Bob Soliday
- Re: Problem building epics base-3.14.6 with recent gcc on linux Robert Soliday
- Problem building epics base-3.14.6 with recent gcc on linux Chip Piller
<2004>
2025
2026
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
