Question: Are you saying that this problem exists in the gcc 2.7.2 compiler AND the 2.9.6 (vxWorks 5.5.x) compiler for both the 68K and PPC? I understood that what WRS shiped for Tornado 2.x was a mixture of two compilers - the C front end from gcc-2.7.2 (to retain backwards compatibility of the object files with earlier versions of vxWorks), and the C++ front end from EGCS (to get updated C++ support). This optimizer problem has only been noticed on the 68K target, and not just in compiler versions built from the GCC sources you provide - my official WRS Tornado 2.0.2 compiler does exactly the same thing. I confirmed Ron Sliuter's report about the code generated for epicsThreadSleepQuantum(), which is actually a very simple routine. Here's the complete test file that generates the error: ======================================================================== #include <vxWorks.h> #include <stdio.h> #include <sysLib.h> #ifdef __cplusplus #define EXPORT extern "C" #else #define EXPORT #endif EXPORT double bug(); /* Tornado compilers for 68k have an optimizer bug at -O1 and above; the
* code generated for bug() is incorrect. The vxWorksBrokenCompilerTest
* routine tests for that bug, and must appear above the code it calls or
* or the optimizer may inline epicsThreadSleepQuantum() */
EXPORT int vxWorksBrokenCompilerTest()
double tick = bug();
double one = tick * (double) sysClkRateGet();
int ok = (one > 0.999) && (one < 1.001);
printf("%s: bug() = %f\n", ok ? "Ok" : "BROKEN", tick);
return ok;
}EXPORT double bug()
double HZ = (double) sysClkRateGet();
return 1.0 / HZ;
}======================================================================== This is the code I get for the bug() routine using -O3: bug: ada916 4856 PEA (A6) ada918 2c4f MOVEA .L A7,A6 ada91a 61ff ff54 57fc BSR sysClkRateGet ada920 203c 3ff0 0000 MOVE .L #0x3ff00000,D0 ada926 7200 MOVEQ #0,D1 ada928 2f01 MOVE .L D1,-(A7) ada92a 2f00 MOVE .L D0,-(A7) ada92c f21f 5444 FDMOVE.D (A7)+,F0 ada930 f200 4064 FDDIV .L D0,F0 ada934 f227 7400 FMOVE .D F0,-(A7) ada938 201f MOVE .L (A7)+,D0 ada93a 221f MOVE .L (A7)+,D1 ada93c 4e5e UNLK A6 ada93e 4e75 RTS Note how in the 4th instruction above, the value from the call to sysClkRateGet() which was returned in D0 gets trashed by the constant 1.0 value being pushed onto the stack. Using -O0, the code generated is this:
bug:
adbfbe 4e56 fff8 LINK .W A6,#0xfff8
adbfc2 61ff ff54 4154 BSR sysClkRateGet
adbfc8 f200 40c4 FDMOVE.L D0,F1
adbfcc f22e 7480 fff8 FMOVE .D F1,(0xfff8,A6)
adbfd2 f23a 5444 ffe0 FDMOVE.D (0xffe0,PC),F0
adbfd8 f22e 5464 fff8 FDDIV .D (0xfff8,A6),F0
adbfde f227 7400 FMOVE .D F0,-(A7)
adbfe2 201f MOVE .L (A7)+,D0
adbfe4 221f MOVE .L (A7)+,D1
adbfe6 6000 0002 BRA 0x00adbfea
adbfea 4e5e UNLK A6
adbfec 4e75 RTSAnd are you also saying that the c++ compiler is not affected? Have you tested this or have experience that confirms this? I thought that was the case, but I was wrong; the identical code gets generated whether I build the source file as C or C++ (and I know it's getting compiled as C++ code because I had to add the export "C" macro). Therefor I'm going to have to turn off the optimizer for C++ code as well. This is very bad news for R3.14 on 68K until we get a compiler fix... - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
