1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asynDriver 4-0
To: [email protected]
Date: Mon, 22 Nov 2004 14:32:19 -0600
asynDriver release 4-0 is now available. See
http://www.aps.anl.gov/epics/modules/soft/asyn/
The release notes start with the statement
APOLOGY: Many interfaces have changed since release 3-3. This is the reason this release is called 4-0.
I would like to expand on this a little.
If you are using the gpib support (devGpib and low level drivers) you should see almost no changes.
If you are using asynManager then, except for an extra argument to report, all old method have exactly the same prototypes as before. You will, however, see new features.
If you are using asynOctet then there are some changes.
If you are using the register based interfaces and devEpics, which were introduced in release R3-3, then you will see major changes. Release 3-3 did come with a warning that the register based interfaces/devEpics was likely to undergo rapid evolution. This happened. We feel that the new interfaces/devEpics is more flexable, easier to implement, and easier to understand.
With the addition of interrupt support asynDriver now has all the core components we have planned.
Hopefully the interfaces will now undergo only minor rather than major evolution.
Also see the Known Problems for things that we did not have time to implement for this release.
Prev: Thales RF transmitter controls Chris Timossi
Next: RE: Thales RF transmitter controls Owens, PH (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Thales RF transmitter controls Gurd, Pamela A.
Next: only 16 enum states? Dirk Zimoch
