when I try to read the choices of an enum field, I only get the first 16. This ist not enough to read all the choices of the LINR field (menuConvert) if there are many breakpoint tables. It's even not enough to read all choices of the STAT field. Is there a fix? What happens if I change in db_access.h #define MAX_ENUM_STATES 16 in #define MAX_ENUM_STATES 255 ? Dirk -- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
