1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building EPICS base
To: "'Krapec Iztok'" <[email protected]>, <[email protected]>
Date: Tue, 23 Nov 2004 09:15:15 -0700
> I am trying to build EPICS base 3.14.6 and I am getting following
This is a known problem. Newer versions of the GNU C++ compiler aggressively
enforce that a private member function can't be a friend. There was no
warning in the past from any compiler that we use. The newest GNU compiler
made the no-doubt carefully considered transition from that behavior to
aborting compilation.
The workaround is to change "friend udpRecvThread::run()" line in udpiiu.h
to "friend class udpRecvThread". This does not make for a more
understandable program, but will probably be the typical response to this
compiler behavior change.
Jeff
> -----Original Message-----
> From: Krapec Iztok [mailto:[email protected]]
> Sent: Tuesday, November 23, 2004 9:04 AM
> To: [email protected]
> Subject: Building EPICS base
> Hello
> I am trying to build EPICS base 3.14.6 and I am getting following error:
> make[3]: Entering directory
> `/home/ikrapec/epics-instal63/base-3.14.6/src/ca/O.linux-x86'
> /usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500  -DOSITHREAD_USE_DEFAULT_STACK      -D_X86_  -DUNIX
> -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I..
> -I../../../include/os/Linux -I../../../include         ../casw.cpp
> In file included from ../casw.cpp:31:
> ../udpiiu.h:73: error: `virtual void udpRecvThread::run()' is private
> ../udpiiu.h:183: error: within this context
> make[3]: *** [casw.o] Error 1
> make[3]: Leaving directory
> make[2]: *** [install.linux-x86] Error 2
> make[2]: Leaving directory `/home/ikrapec/epics-instal63/base-
> 3.14.6/src/ca'
> make[1]: *** [ca.install] Error 2
> make[1]: Leaving directory `/home/ikrapec/epics-instal63/base-
> 3.14.6/src'
> make: *** [src.install] Error 2
> I am using gcc version 3.4.2 and GNU Make 3.80.
> Does somebody know what is the problem?
> LP
> Iztok
Building EPICS base Krapec Iztok
Prev: Re: Building EPICS base Mauro Giacchini
Next: Re: Building EPICS base Robert Soliday
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
