Krapec Iztok wrote: > Hello > > I am trying to build EPICS base 3.14.6 and I am getting following error: > > > make[3]: Entering directory > `/home/ikrapec/epics-instal63/base-3.14.6/src/ca/O.linux-x86' > /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS > -D_XOPEN_SOURCE=500 -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX > -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -I. -I.. > -I../../../include/os/Linux -I../../../include ../casw.cpp > In file included from ../casw.cpp:31: > ../udpiiu.h:73: error: `virtual void udpRecvThread::run()' is private > ../udpiiu.h:183: error: within this context > make[3]: *** [casw.o] Error 1 > make[3]: Leaving directory > `/home/ikrapec/epics-instal63/base-3.14.6/src/ca/O.linux-x86' > make[2]: *** [install.linux-x86] Error 2 > make[2]: Leaving directory `/home/ikrapec/epics-instal63/base-3.14.6/src/ca' > make[1]: *** [ca.install] Error 2 > make[1]: Leaving directory `/home/ikrapec/epics-instal63/base-3.14.6/src' > make: *** [src.install] Error 2 > > I am using gcc version 3.4.2 and GNU Make 3.80. > > Does somebody know what is the problem? > > LP > > Iztok Here is the reply Jeff Hill had after I asked the same question two weeks ago: ------------------------ This is entry 98 in Mantis. That issue is related to interpretation of the C++ standard by the various compilers (can a member function be a friend if it is private to the befriended class). Apparently the committee considered this matter under defect resolution, they initially were in favor of permitting a private member function to be a friend, but were unable to find consensus when all of the nagging details were considered. Recent GNU compilers are apparently aggressively enforcing the forbid decision. A fix has been committed to CVS, and will show up in R3.14.7. A temporary workaround is as follows. Replace this: friend void udpRecvThread::run (); With this: friend class udpRecvThread; On line 183 in udpiiu.h. -------------------------- If I remember correctly, this problem shows up in another file where you have to make a similar change. --Bob
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
