Title: Message
Russell,
The features I was discussing only
apply to generic device support for drivers that use the new asynDriver
interfaces. Since your drivers are not based on asyn, and you are not
using the asyn generic device support, then this will not be a problem for
you. Nothing in EPICS base has changed in this regard.
If you
begin to use asyn-based drivers, and you don't want the records to set the
value during init_record you can:
- Use
non-generic device support
Write an asyn SIMULATION driver, that looks just like the real driver, but does
not talk to hardware
I am curious
about a closely related issue that I fear will arise when we try to
upgrade our version of EPICS from 3.13.8 to use the newer software. My
code runs in both hardware and simulation modes to allow the software to be
tested without having the hardware attached. When the IOC boots, it does
not know which mode it is supposed to be in. The operator sets
HARDWARE/SIMULATION mode flag, then runs an INITIALISE action to open
communications with hardware or with the simulator, as appropriate. Very
bad things happen if the EPICS drivers attempt to read back values from
nonexistent hardware, and I have put a considerable effort into the startup
code to ensure that I/O records do not process on startup.
So here is
my question: How can I PREVENT an output record from reading back a value
during init_record from hardware that may or may not
exist?
Cheers, Dr. Russell O. Redman Tel: (250) 363-6917 | Fax:
(250) 363-0045 <mailto:[email protected]>
National Research Council Canada | Conseil national de recherches Canada
5071 West Saanich Road
| 5071 West
Saanich Road Victoria, B. C. V9E 2E7
| Victoria, C.-B. V9E
2E7 Government of Canada
Gouvernement du Canada --
- RE: Initial value readback from hardware into output records Ralph Lange
Re: Initial value readback from hardware into output records Russell Redman
Re: Initial value readback from hardware into output records Benjamin Franksen
<2004>
2025
2026
<2004>
2025
2026
