Subject: |
Re: Initial value readback from hardware into output records |
Benjamin Franksen <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 9 Dec 2004 00:47:57 +0100 |
On Tuesday 07 December 2004 14:15, Mark Rivers wrote:
> Benjamin Franksen wrote:
> > Reading back initial values of output records via init_record (what is
> > usually called 'warm reboot' or 'bumpless reboot') has never worked
> > with asynchronous device supports. In particular, to my knowledge
> > devGpib doesn't provided any support for warm reboot (I doubt the new
> > asynDriver based GPIB support is any different here; if it is, I'd be
> > interested to know).
> The generic device support for EPICS records in asyn 4.0 sets the
> initial values of output records to the current device value in
> init_record.
> [...snip code fragment...]
> So it calls the driver's getBounds() method so that linear conversion
> can work, and then calls asynInt32SyncIO->read() to get the current
> value, setting ao->rval to that. Note that since this is being done in
> iocInit it is OK to wait, and a synchronous call is being used (no
> callback needed).
Most interesting, this. When (years ago) I proposed such a solution the answer
was invariably that in this case the IOC initialization could be delayed
indefinitely and that this was not tolerable. Imagine 1000 CAN objects with
timeout set to 1 second each; IOC boots and just hangs in iocInit... until
after a few minutes you loose your patience, go over to see what's wrong and
find out some idiot (probably yourself) has unplugged the cable. It seems
cable connectors have become much more reliable, if not intelligent, since
then...
Seriously, there *is* a clean and simple solution that avoids indefinite
blocking inside iocInit. For asynchronous device supports, init_record must
act like the first stage of asynch (read) processing. I.e. leave the record
in an active state (PACT=1) and set up a normal process callback. Since PACT
is set, the record can't be processed in the normal way (and remains in
UDF/INVALID state). If and when the callback arrives, (read-) processing
initiated by init_record completes and everything goes back to normal. You
just need to make sure that the device support's write method knows it has to
complete a read (and not a write) the first time it gets called.
BESSY's MultiCAN library works this way.
Ben
- RE: Initial value readback from hardware into output records Mark Rivers
EPICS problem Mark Rivers
<2004>
2025
2026
Re: Initial value readback from hardware into output records Russell Redman
<2004>
2025
2026
