1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Initial value readback from hardware into output records
To: "Allison, Stephanie" <[email protected]>
Cc: [email protected]
Date: Sun, 12 Dec 2004 14:45:22 +1100
Hi Stephanie,
Thank-you for this.  I understand how to do your solutions (1) and (3), but
it is solution number (2) which I am primarily interested in:
>(2) For records that have readback available and initialization device
support, >the setpoint is set to the readback by device support at the
proper time in >iocInit.
I have never seen any concrete examples of how to do this in the real world
and would appreciate some help in understanding the details.  For instance,
I presume that the readback must be obtained during Device Support's
Init_Record() routine but I have not yet fully grasped how this happens.
For instance, the IOC Developers Guide talks about Driver Support and I
presume that Device Support must call an API provided by Driver Support to
get the readback value.
But where do I obtain these low-level drivers from?  Do I have to write
them myself?  Or are they generally available somewhere?  Or does Device
Support just talk directly to the hardware, and if so what does EPICS
provide to help with this?
Steve Banks
Australian Synchrotron Project
Department of Infrastructure
Level 17, 80 Collins Street
Melbourne   VIC   3000
tel:  +613 9655 6303
fax:  +613 9655 8666
web: www.synchrotron.vic.gov.au
Any personal or sensitive information contained in this email and
attachments must be handled in accordance with the Victorian Information
Privacy Act 2000, the Health Records Act 2001 or the Privacy Act 1988
(Commonwealth), as applicable.
This email, including all attachments, is confidential.  If you are not the
intended recipient, you must not disclose, distribute, copy or use the
information contained in this email or attachments.  Any confidentiality or
privilege is not waived or lost because this email has been sent to you in
error.  If you have received it in error, please let us know by reply
email, delete it from your system and destroy any copies.
Re: Initial value readback from hardware into output records Benjamin Franksen
Prev: RE: Initial value readback from hardware into output records Allison, Stephanie
Next: Re: Initial value readback from hardware into output records Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
