Subject: |
Re: Initial value readback from hardware into output records |
Benjamin Franksen <[email protected]> |
To: |
[email protected] |
Date: |
Sun, 12 Dec 2004 17:21:23 +0100 |
On Sunday 12 December 2004 04:45, [email protected] wrote:
> Hi Stephanie,
> Thank-you for this. I understand how to do your solutions (1) and (3), but
> it is solution number (2) which I am primarily interested in:
> >(2) For records that have readback available and initialization device
> support, >the setpoint is set to the readback by device support at the
> proper time in >iocInit.
> I have never seen any concrete examples of how to do this in the real world
> and would appreciate some help in understanding the details. For instance,
> I presume that the readback must be obtained during Device Support's
> Init_Record() routine but I have not yet fully grasped how this happens.
Take a look at one of the available hardware support modules, see
http://www.aps.anl.gov/epics/modules/index.php. If you find your hardware
listed, you are done (mostly). Otherwise, you might want to ask on tech-talk
if anyone has written devise support for your hardware. Otherwise take a
second look at the above web page and try to find a similar device support
and modify the code accordingly. Also, read Application Developer's Guide,
Chapter on Device Support.
> For instance, the IOC Developers Guide talks about Driver Support and I
> presume that Device Support must call an API provided by Driver Support to
> get the readback value.
Not necessarily. For simple devices, especially synchronous ones, device
support will usually talk directly to the device.
> But where do I obtain these low-level drivers from? Do I have to write
> them myself?
Yes, unless you find someone else who already did.
> Or are they generally available somewhere?
See above.
> Or does Device
> Support just talk directly to the hardware, and if so what does EPICS
> provide to help with this?
EPICS rovides a library to access devices on the VMEbus under VxWorks. See the
Application Developer's Guide for details.
Ben
- RE: Initial value readback from hardware into output records Steven . Banks
Is anybody investigating using state-full web services with EPICS APIs? Bill St. Arnaud
<2004>
2025
2026
EPICS problem Mark Rivers
<2004>
2025
2026
