Technically, that seems like an ideal solution to my particular application. It is simple to implement, is logically consistent with the SEL record behavior, completely solves my problem (e.g. I don't need a monitor on SELN), and is unlikely to be incompatible with existing use. Sociology is another issue..... It seems unlikely to me that your suggestion would break anything but the most contrived and non-mainstream application. However, the larger the user base, the more likely contrived and non-mainstream applications become! Once can certainly avoid breaking legacy application by introducing yet more mode selections (e.g. "High Signal Index"), while leaving the behavior of existing mode selections unchanged. However, that could lead to unecessary, and potentially confusing "mode creep". I suppose big, bold warnings in EPICS release notes should be sufficient to warn users of new record functionality that comes with new versions of EPICS, especially if they come with guidance on how to work around new functionality which "breaks" existing applications. I do wonder if anyone ever really reads release notes before they commit to an upgrade, though........ I could make my own record for my own application, but that seems a rather heavy-handed approach, especially since I can use a group of CALC records or a single SUBROUTINE record, and not incur the maintenance burden of a new record (which has 99% functionality overlap with the SEL record). I look forward to watching the "social side" of how this issue plays out. Meanwhile, I find that by pairing each of my "goodness" ao records with a calc record, and using two SEL records, I can implement my application in a understandable (IMHO) way, so the issue has become moot. If your proposed functionality becomes available, all those CALC records and one SEL record would become unecessary. -- Larry
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
