1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: database conversion
To: john sinclair <[email protected]>
Cc: tech talk <[email protected]>
Date: Mon, 20 Dec 2004 13:08:20 -0600
john sinclair wrote:
For R3.14.6, ai record, the following:
field(LINR, "LINEAR")
does not generate a database parse error, but after iocInit the LINR field is set to 0 and the behavior of the record seems to be independent of the value of ESLO.
What device support are you using for this record? Some device support layers set LINR to 0 because they will write their input values directly to the VAL field without doing any input conversions at all.
Poking a 2 into LINR seems to make the record aware of the ESLO field.
Can anyone explain this. I've read the record manual but am still not certain of the correct value for the LINR field.
LINR is a menu field, the definition of menuConvert is found in <base>/src/bpt/menuConvert.dbd (and gets installed into <base>/dbd) but may be overridden by your IOC application if it needs to load any other breakpoint tables.
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
database conversion john sinclair
Prev: Re: Index of highest value Tim Mooney
Next: Re: database conversion john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: database conversion john sinclair
