1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: database conversion
To: tech talk <[email protected]>
Date: Mon, 20 Dec 2004 19:16:52 +0000
The problem is not with EPICS. The ethernetIP device support code explicitly
sets LINR to 0 during init.
John Sinclair
On Monday 20 December 2004 5:57 pm, you wrote:
> For R3.14.6, ai record, the following:
>        field(LINR, "LINEAR")
> does not generate a database parse error, but after iocInit the LINR field
> is set to 0 and the behavior of the record seems to be independent of the
> value of ESLO.
> Poking a 2 into LINR seems to make the record aware of the ESLO field.
> Can anyone explain this. I've read the record manual but am still not
> certain of the correct value for the LINR field.
John Sinclair
database conversion john sinclair
Prev: Re: database conversion Andrew Johnson
Next: Re: Index of highest value Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Porting db file generation from 3.13 to 3.14 Benjamin Franksen
