I'm in the early stages of porting a 3.13 application to 3.14 and got
stuck almost immediately.
Our typical application creates X.db using X.substitutions and template
files a.template and b.template. X.substitutions looks like this
file a.template {
{ NAME="a1" }
{ NAME="a2" }
file b.template {
{ NAME="b1" }
{ NAME="b2" }
{ NAME="b3" }
In my old (3.13) Makefile.Host I have
USES_TEMPLATE = a.template b.template
DB = X.db
which creates X.db by calling (more or less)
msi -S X.substitutions > X.db
That is, msi is used as substitution for host side dbLoadTemplate.
What definitions do I need in my Makefile to make this work in 3.14?
Make complains about a missing "../X.template".
I read chapter 4 of the ADG but there is no clue to what I should do
here. The doc seems to suggest that expanding substitutions files in
the dbLoadTemplate style is no longer supported because it seems that
*one* template file is required for each substitution file and a subst
files like the above obviously needs not one but many different
template files.
Almost all of our applications use above style to expand db on the host
side and most of the substitutions files are generated by scripts from
a relational Database.
I am quite astonished that I seem to be the first one stumbling over
this. Any suggestion on how to proceed would be greatly appreciated.
Ben
Re: Micos Motor Support query. David Maden
Has anyone built EDM for OS X? Josh Stein
<2004>
2025
2026
Re: database conversion john sinclair
<2004>
2025
2026
