1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Connect rates under RTEMS
To: [email protected], [email protected]
Date: Tue, 18 Jan 2005 12:33:15 -0600
wnolan wrote:
Hi all, I was curious what sort or rates are being observed using the catime
utility for RTEMS installations.
On a mvme2307 under RTEMS 4.6.2 running EPICS 3.14.6 I am seeing a
extream slowdown from our VX works installations and was wondering if it
was tyipical.
--- Test data Same Hardware
MVME2307
1x OMS VME58
1x Jerger VSC16
1x ACROMAG AVME9440
and process database( about 30 records ), no state programs running. targeting a calc input field for 10000 connections. VX-works gives channel connect test
Elapsed Per Item = 0.00031412 sec, 3183.5 Items per sec, 1.8 Mbps
Search tries per chan - mean=1.010000 std dev=0.099499 min=1.000000
max=2.000000
RTEMS gives channel connect test
Elapsed Per Item = 0.00358250 sec, 279.1 Items per sec, 0.2 Mbps
Search tries per chan - mean=2.210500 std dev=1.631377 min=1.000000
max=8.000000
I am also seeing the slowdown on ASYN Get tests VX works seems to run about 6 Mbps where in the same test RTEMS is
running at about 1 Mbps
A factor of 10 on channel connect and a factor of 6 on Asyn Get's
Sync gets are running at about the same rate under both systems , just
under 1 Mbps
Any help, Pointers or comparative data would be a help,
Bill Nolan [email protected]
The RTEMS implementation of osiSufficentSpaceInPool calls malloc_free_space. This turns out to be a very expensive operation. Take out the call to malloc_free_space and the channel connect rate goes way up. I think that the RTEMS maintainers have made malloc_free_space quite a bit quicker but the change is still only in the RTEMS CVS repository.
BTW - the vxWorks implementation of osiSufficentSpaceInPool is of questionable usefulness so it's not really clear to me that there's any point in using this routine at all (Jeff Hill disagrees with me on this.....).
Eric Norum                                 [email protected]
Advanced Photon Source                     Phone: (630) 252-4793
Argonne National Laboratory
RE: CA Connect rates under RTEMS Jeff Hill
Re: CA Connect rates under RTEMS (vxWorks, too) Kate Feng
CA Connect rates under RTEMS wnolan
Prev: CA Connect rates under RTEMS wnolan
Next: RE: CA Connect rates under RTEMS Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
