1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Connect rates under RTEMS (vxWorks, too)
To: [email protected]
Cc: [email protected], [email protected], [email protected], [email protected]
Date: Tue, 18 Jan 2005 15:01:33 -0500
Is it less confusing  if EPICS/vxWorks, EPICS/RTEMS  and EPICS/other O.S.
can unify this implementation ?   Perhaps, the vxWorks implementation
could be helpful,  although could'nt be ideal ?  I do not have vxWorks for
3.14 to verify this.  However,  here is some of my thoughts, hoping to
hear others.
1) Could the vxWorks implementation be ported to the  RTEMS as a default ?
Perhaps, that function could be turned off  as an option, although not safe,
in case of demanding application  assuming the users have  absloutely
knowledge and control of the client access of the IOC
Jeff Hill Wrote :
>It would of course also help to allocate *all* memory off of free lists,
> but this is not easy especially with any approach to variable length strings
> that requires contiguous storage.
2) How about at least for the  array and waveform (e.g. image processing) ?
Is it easy  ?
Kate
Re: CA Connect rates under RTEMS (vxWorks, too) Eric Norum
RE: CA Connect rates under RTEMS (vxWorks, too) Jeff Hill
CA Connect rates under RTEMS wnolan
Re: CA Connect rates under RTEMS Eric Norum
Prev: Re: CA Connect rates under RTEMS Till Straumann
Next: Re: CA Connect rates under RTEMS (vxWorks, too) Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA Connect rates under RTEMS Jeff Hill
