1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Connect rates under RTEMS (vxWorks, too)
To: Kate Feng <[email protected]>
Cc: [email protected]
Date: Tue, 18 Jan 2005 14:09:55 -0600
Kate Feng wrote:
Is it less confusing  if EPICS/vxWorks, EPICS/RTEMS  and EPICS/other O.S.
can unify this implementation ?   Perhaps, the vxWorks implementation
could be helpful,  although could'nt be ideal ?  I do not have vxWorks for
3.14 to verify this.  However,  here is some of my thoughts, hoping to
hear others.
1) Could the vxWorks implementation be ported to the RTEMS as a default ? Perhaps, that function could be turned off as an option, although not safe, in case of demanding application assuming the users have absloutely knowledge and control of the client access of the IOC
I believe that the new RTEMS version of malloc_free_space() is efficient enough that the connect rates should be acceptable with the existing implementation of osiSufficentSpaceInPool().
Eric Norum                                 [email protected]
Advanced Photon Source                     Phone: (630) 252-4793
Argonne National Laboratory
CA Connect rates under RTEMS wnolan
Re: CA Connect rates under RTEMS Eric Norum
Re: CA Connect rates under RTEMS (vxWorks, too) Kate Feng
Prev: Re: CA Connect rates under RTEMS (vxWorks, too) Kate Feng
Next: RE: CA Connect rates under RTEMS (vxWorks, too) Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
