Andrew Johnson wrote:
Emmanuel Mayssat wrote:
I would like to check for the settings of an environment variable in
iocsh. If the envrionment variable is not set, then I want to set it to
a default value.
Is there any way to do that ?
Yes, but how depends what variables you're trying to set, and whether
this is for a particular IOC or all IOCs using a particular version of
EPICS Base. The ioc shell is not intended to be a programming language,
and it doesn't (and never will) provide conditional commands, so you
can't just put something in the startup script that will work for any
environment variable.
I had interpreted this yet different, and my first reaction was
"you use a subroutine record" ...
What are you trying to do?
Aloha,
Maren
- Re: if-then-else in iocsh Emmanuel Mayssat
- if-then-else in iocsh Emmanuel Mayssat
- Re: if-then-else in iocsh Andrew Johnson
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
