1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM and Text Control
To: Gavin Smith <[email protected]>
Cc: [email protected]
Date: Mon, 31 Jan 2005 11:30:46 +0100
If you're really really interested, you also might want to look at the lengthy tech-talk thread starting with
http://www.aps.anl.gov/epics/tech-talk/2002/msg00186.php
for a more in-depth discussion of drive limitation issues.
But to make your screen work - Pete's answer was what you were most probably looking for.
Use DRVH & DRVL so that the database rejects out of range values
rather than relying on the client application to do this.
I have noticed that in EDM the text control seems to accept any value given to it by the user, regardless of whether it is outside of HOPR or LOPR. Is there some way to fix this, or a workaround that other people have?
I'm assuming for the moment that we need a user screen to reject output outside normal parameters (e.g. for a 0-10 scale, 30000 is right out.). I notice that the slider control can pop up a text box when clicked, and this respects HOPR and LOPR. Is there some way to make the text control do this?
Gavin Smith.
RE: EDM and Text Control Owens, PH (Peter)
Prev: RE: EDM and Text Control Owens, PH (Peter)
Next: RE: EDM and Text Control Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
