1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EDM and Text Control
To: <[email protected]>
Date: Mon, 31 Jan 2005 10:32:06 -0800
> Use DRVH & DRVL so that the database rejects out of range values
> rather than relying on the client application to do this.
Just a side note about AO limit checking and monitor updates.  If an AO is already at a DRV limit and the user types in a value beyond the DRV limit, the ao record processes and correctly sets the value back to the DRV limit but if MDEL is set to 0, the record will NOT post a monitor.  However, depending on how the CA client gui is programmed (say if it only updates on monitor change), it may leave the user's new value showing.  I think most EPICS gui clients are OK but to be safe, for AO records that aren't knobbed or periodically processed, I set MDEL to -1 so it updates whenever if processes.  You may want to test that your gui's do the right thing and override the user's value with the last value in this case.
Stephanie Allison
Prev: Re: EDM and Text Control Ralph Lange
Next: seq 2.0.10 Laznovsky, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EDM and Text Control Gavin Smith
