1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: R3.14.7 next build error ?!
To: "'Zoltan Kakucs'" <[email protected]>, <[email protected]>
Date: Thu, 3 Feb 2005 08:51:30 -0700
Hi Zoltan,
I don?t see that when I build the R3.14 branch on Solaris. That type of
compile time error typically occurs because a pure virtual function is not
defined in the derived class, but I don?t see supporting evidence in the
source code. I am building with the following version of the Sun compiler.
bash-2.05b$ /opt/SUNWspro/bin/CC -V
CC: Forte Developer 7 C++ 5.4 Patch 111715-13 2003/12/11
Jeff
> -----Original Message-----
> From: Zoltan Kakucs [mailto:[email protected]]
> Sent: Thursday, February 03, 2005 1:35 AM
> To: Tech Talk
> Subject: R3.14.7 next build error ?!
> Hi again,
> I've got the next error building the release 3.14.7:
> /opt/SUNWspro/bin/CC -c   -D_POSIX_C_SOURCE=199506L
> -D_XOPEN_SOURCE=500         -DUNIX  -DSOLARIS=8 -mt  -D__EXTENSIONS__
> -O  +w           -I. -I.. -I../../../../include/os/solaris
> -I../../../../include         ../epicsExceptionTest.cpp
> "../epicsExceptionTest.cpp", line 106: Error: Cannot create a variable
> for abstract class exThread.
> 1 Error(s) detected.
> gmake[3]: *** [epicsExceptionTest.o] Error 1
> Do somebody knows how to fix it ? (before I begin to search for)
> Regards,
> Zoltan
> Zoltan Kakucs, M.Sc.
> Deutsches Elektronen-Synchrotron DESY
> in der Helmholtz-Gemeinschaft
> Cryogenic Control Group
> Notkestraße 85
> D-22607 Hamburg
> +49 (0) 40 8998 - 3283 Voice
> +49 (0) 40 8998 - 4388 Fax
> mailto: [email protected]
> DESY Hamburg at http://www.desy.de
>  "Mut bedeutet nicht, keine Angst zu haben,
>                   sondern es ist die Entscheidung,
>           dass etwas anderes wichtiger ist, als die Angst."
>  "Courage is not the absence of fear,
> 		  but rather the judgement that something
> 	  else is more important than fear"
>                                    	  Ambrose Red Moon
Re: R3.14.7 next build error ?! Ralph Lange
R3.14.7 next build error ?! Zoltan Kakucs
Prev: Re: DeltaTau PCI Motor Control Boards and Linux Ronald L. Sluiter
Next: STATIC softIOC Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: R3.14.7 next build error ?! Zoltan Kakucs
Next: Re: R3.14.7 next build error ?! Ralph Lange
