On Thu, 2005-02-03 at 10:58 -0700, Jeff Hill wrote:
> In past versions of EPICS, if the caRepeater executable could not be found,
> the repeater daemon process was created on POSIX by making a copy of the
> current process using the fork system call, but this has been a source of
> confusion and subtle problems (to put it mildly). With newer versions of
> EPICS this fall back behavior has been eliminated.
> It is certainly possible for the repeater daemon to be implemented as an
> independent thread inside of the IOC process. This is in fact what is done
> on RTEMS and vxWorks. However, on process based OS this causes issues if an
> external CA client becomes dependent on this IOC resident CA repeater and,
> at some later time, the IOC containing the repeater is stopped. Given a weak
> cause and effect pattern of behavior and the likelihood that configuration
> decisions made in the past will not be remembered when adding additional
> clients to the same host in the future then I am inclined to conclude that
> an IOC resident CA repeaters would be an error prone and confusing option on
> process based OS.
> I am open to suggestions, but my current perspective is that, on process
> based OS, the CA repeater must be an independent process started from an
> independent executable.
> The CA repeater's purpose is to receive CA server beacons and fan them out
> to all of the CA clients running in the same host. Most modern IP kernels
> now allow multiple listeners on the same UDP port, so that is no longer the
> reason for the CA Repeater. Unfortunately, there is still a defect in most
> IP kernels where UDP broadcasts reach multiple listeners on the same UDP
> port, but UDP unicasts (single host addressed datagrams) do not. Therefore,
> the CA repeater must still exist, and there can only be one of them on each
> host.
This is the case for process-based IOCs as well as vxWorks and RTEMS,
right?
> Use of IP multicasts instead of IP broadcasts for CA beacons is something
> that could be considered for future versions. This might allow the CA
> repeater to be phased out.
> Jeff
> > -----Original Message-----
> > From: Paul Sichta [mailto:[email protected]]
> > Sent: Thursday, February 03, 2005 9:49 AM
> > To: [email protected]
> > Subject: STATIC softIOC
> > Hi,
> > I'm trying to make a deployable, STATIC build of a soft IOC
> > application for Linux. In base 3.14.7 I edited
> > configure/CONFIG to use STATIC=YES. Then I made an
> > 'example' application using makeBaseApp.pl -t , then again
> > with -i -t. Finally, I copied the app directory to another
> > Linux computer, which doesn't have base.
> > When I start the soft IOC task, AND when the database has an
> > INP field linked to a separate IOC, I get the warning "The
> > executable "caRepeater" couldn't be located", about a minute
> > later the IOC console displays "CA client library is unable
> > to contact CA repeater after 50 tries.", then no more
> > errors. All the while the record with the INP link is
> > working.
> > Other than copying the base/bin and lib dirs to the target
> > machine and incorporating their paths, is there a method to
> > get the caRepeater (et al) included in the application's
> > bin/lib? My old vxWorks IOC's have the caRepeater task
> > bundled in (somehow).
> > Thanks,
> > Paul Sichta
> > Princeton Plasma Physics Laboratory
> > 609-243-3477 FAX 3030
- RE: STATIC softIOC Jeff Hill
Re: STATIC softIOC Paul Sichta
PPT and PDF files of the presetation in EPICS meeting at TOKAI,JAPAN are now available on the web. Noboru Yamamoto
<2005>
2025
2026
<2005>
2025
2026
