1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SSCAN and EDM
To: Iztok Krapec <[email protected]>
Cc: [email protected]
Date: Wed, 16 Feb 2005 08:46:37 -0600
Iztok Krapec wrote:
Hi all!
I am using the SSCAN record for scanning and EDM's XY graph to show the results. Is there any way to update the graph each time when new value is added to the arrays of scanned values (DnnDA fields)?
I have the EDM 1-10-1v.
LP
Iztok
How often the array is updated is a function of the SSCAN record and when it decides to post the new array ... I think.
I have used the SCAN record with MEDM and have wrestled with the same need. My solution was to do two plots ... "Scan In Progress" and "Scan Results. "Scan In Progress" plots the current values for the detector vs. the current value of the positioners (DnCV vs PnCV) so it updates at each point. "Scan Results" plots the final arrays. With MEDM, you can put these on top of each other and make one visible at a time (which is cool). An advantage of having both visible is that one can see the previous scan results while the new scan is in progress ("Look, this peak moved!").
Ned
Re: SSCAN and EDM Tim Mooney
SSCAN and EDM Iztok Krapec
Prev: Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
Next: calc and infinity Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: SSCAN and EDM Iztok Krapec
Next: Re: SSCAN and EDM Tim Mooney
