1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: calc and infinity
To: TECHTALK <[email protected]>
Date: Wed, 16 Feb 2005 16:50:14 +0100
Hi all,
what's the calc record supposed to do if it calculates infinity?
I have tested the following with R3.13.2/vxWorks5.5/ppc and R3.14.6/Linux/x86
1)
field (CALC, "A/B")
If B is 0.0, the record becomes invalid (as expected) but the value does not change to 'inf' but stays the previous value. In my opinion this is wrong behaviour. (On the other hand, the value IS invalid, thus it might be any number.)
2)
field (C, "inf")
field (CALC, "B?A/B:C")
This works. VAL is 'inf' and the record is invalid.
If one argues in that the record is invalid in 1) because VAL couldn't be calculated, why is it invalid in 2) even though it is accurately inf?
If one argues that the value IS inf in 2), why is the record invalid and why is the value wrong in 1)?
3)
field (CALC, "B?A/B:inf")
Does not work. The string inf is not accepted as a constant in the CALC field. This is inconsistent with the behaviour of DBF_DOUBLE fields.
I know that there has been some discussion about infinity and what it means in the 'real world', in EPICS and for a driver. But there are cases, where infinity had a real meaning. E.g. the resistance if a cable is broken. I miss the possibility to have a valid infinity.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
Prev: Re: SSCAN and EDM Ned Arnold
Next: Re: SSCAN and EDM Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SSCAN and EDM Tim Mooney
Next: load error for vxworks-ppc403 Chris Timossi
