1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: load error for vxworks-ppc403
To: "'Chris Timossi'" <[email protected]>, <[email protected]>
Date: Wed, 16 Feb 2005 14:01:39 -0700
Chris,
I suspect that you need to go into the configuration for building
your vxWorks image and include the standard C++ string library
module.
My intent was to avoid using the C++ standard string library, but
it appears that I have inadvertently pulled made references to it
when using standard exceptions. I see how to fix this, and I will
need to attend to this when I get some time.
Are you using vxWorks 6.0? If so you should probably also read
Mantis entry 179 (a build time issue).
Jeff
> -----Original Message-----
> From: Chris Timossi [mailto:[email protected]]
> Sent: Wednesday, February 16, 2005 1:33 PM
> To: [email protected]
> Subject: load error for vxworks-ppc403
> We're attempting to build and load ioc example code for a PPC
> 405 on a
> VxWorks platform from Xilinx (I've created configure files for
> vxWorks-ppc403). We built the code using gcc/tornado using
> epics base
> 3.14.6.
> It's almost loading but it looks like there's missing symbols
> from the
> C++ string package that we cant resolve. Has anyone seen a
> message
> similar to the following when loading :
> -> ld < Vrtx.munch
> Undefined symbol:
> clone__Q2t12basic_string3ZcZt18string_char_traits1ZcZt24__defa
> ult_alloc_template2b1i03Rep (binding 1 type 0)
> Undefined symbol:
> __dl__Q2t12basic_string3ZcZt18string_char_traits1ZcZt24__defau
> lt_alloc_template2b1i03RepPv (binding 1 type 0)
> ld error: Module contains undefined symbol(s) and may be
> unusable.
> value = 0 = 0x0
load error for vxworks-ppc403 Chris Timossi
Prev: Re: load error for vxworks-ppc403 Ronald L. Sluiter
Next: Strict aliasing Al-Adwan Ahed
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
