1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: result of date command on IOC of EVG
To: [email protected]
Date: Wed, 23 Feb 2005 14:44:52 +0800 (CST)
Hi All,
I'm trying to record the start time and end time of a small application of
mine on timing system. Hardware: EVG-110, IOC MVME5100. Software: Solaris
8, EPICS base 3.13.8, egRecord, erRecord, egeventRecord, ereventRecord,
timestampRecord. The interval between the start time and end time should
be less than 20 milli seconds. But I found that the start time and end
time recorded are always the same, around the booting time of the IOC. The
command 'date' on IOC gives the same time always, too. With this IOC, if I
download other applications without the event system library, the command
'date' works correctly.
So is there something that I may miss setting up? Could anybody give me
some suggestions?
Thank you very much,
Ge
Re: result of date command on IOC of EVG Korhonen Timo
Prev: Re: Flavors of Linux D. Peter Siddons
Next: Building EPICS base 최현미
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Data Access Class Library Tutorial Liyu, Andrei
Next: Re: result of date command on IOC of EVG Korhonen Timo
