Hi All, The present timestamp driver (drvTS) is built so that when it sees that event system cards are present it silently assumes that you want to use them for maintaining the time also, unless you explicitly tell it not to do so. However, the event system has to be set up also before it is able to deliver the timestamps. The configuration of the timestamp mechanism is done with the call TSconfigure in startup script. To use the event system, you need either to supply timestamp events from an external clock or configure the EVG to generate them internally. I attached a document about the current drvTS implementation, with some comments about my thought to improve it (some time ago.) This is not a definitive document, so please use it for reference only. We are in progress of rewriting the drvTS but day-to-day work always seems to take preference so the progress is not as fast as we would like. But it is in progress, anyway. I hope this helps. Timo (ps. Ge, I still owe you the example templates. We try to put them together and send them to you.) Thank you very much, --
Timo Korhonen PSI (Paul Scherrer Institut)
CH-5232 Villigen PSI
tel + 41- 56 3103262 fax + 41 - 56 310 3383
e-mail: [email protected]
TSAPI.pdf
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
