As many of you will know - I have been skeptical of the usefulness
of using an RDBMS for managing and generating epics configuration
files. I do think however the APS scheme of using Oracle to report
on the actual status of iocs and client configurations is excellent!
However one way to look at the problems of the present efforts to use a
RDBMS, is as an interesting challenge! So I would like to ask any of you
who have or are planing to use an RDBMS - to send me a short list of
your list of requirements for such a system. I would prefer a list of
what you think such a system should do, rather than how it should be
done, or what your actual system does.
As a starting point here are some ideas:
1. Be able to quickly and easily load or modify the relational
database from new or modified template, substitution, or client
(archiver, alarmhandler, edm, ...) configuration files.
2. To enable non Epics specialists to quickly and easily modify
the default field values for an Epics database, or client
configurations. Optionaly also change the on-line value.
3. Be able to quickly and easily generate Epics template,
substitution, startup, and client config files from the relational
database.
4. Be able to roll back to any given version of a system, ioc, or
device, based on date/time or an alphanumeric 'tag'.
5. To be quick and easy to install and maintain.
As this topic has has a high risk of spontaneous combustion (email flame
wars) I would ask you send your responses directly to me and I will pull
them together. I could start a new email list if there is interest.
- Re: Epics research - RDBMS support for Epics Trivan Pal
Re: result of date command on IOC of EVG Korhonen Timo
<2005>
2025
2026
Re: Building EPICS base Noboru Yamamoto
<2005>
2025
2026
