1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: calc record question
To: [email protected]
Date: Fri, 25 Feb 2005 13:34:01 -1000
Hi all,
I need/partly have the following application:
An IOC provides a (floating point, if that matters) number that
depends on something in this IOC to another IOC where it needs
to be added into a calc record. We do this in other places, and
in itself it isn't a problem. The question I have is:
What happens if the first IOC is switched off?
(The number it contributes should be switched to 0.0 before it
is turned off. This IOC may be switched off for months at a
time.)
Will the calc record treat the non-existing input as a 0?
Will it also do so when it is rebooted?
Maren
(trying to avoid putting in a switch)
Re: calc record question Marty Kraimer
Prev: XAL workshop at PAC05? Thomas Pelaia
Next: Twos compliment and Ai Records Gavin Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: calc record question Marty Kraimer
