Maren Purves wrote:
Hi all,
I need/partly have the following application:
An IOC provides a (floating point, if that matters) number that
depends on something in this IOC to another IOC where it needs
to be added into a calc record. We do this in other places, and
in itself it isn't a problem. The question I have is:
What happens if the first IOC is switched off?
(The number it contributes should be switched to 0.0 before it
is turned off. This IOC may be switched off for months at a
time.)
Will the calc record treat the non-existing input as a 0?
Will it also do so when it is rebooted?
Maren
(trying to avoid putting in a switch)
The calc record will continue to use the value it last obtained or 0.0
if it never got a value from the other ioc. If you specify MS on the
link the calc record will go into alarm if the other IOC is down.
Here is a way to do what you require. Create the following two
additional records
record(ai,"<actualLink>") {
field(INP,"<pvInOtherIOC> CP MS")
record(calc,"<checkStatus>") {
field(INPA,"<actualLink> ")
field(INPB,"<actualLink>.SEVR")
#SEVR=3 means INVALID_ALARM
field(CALC,"(B=3)?0.0:A")
Than have your original calc record link to <checkStatus> instead of
<pvInOtherIOC>, e.g.
field(INP<X>,"<checkStatus> PP")
Perhaps someone can think of a more clever way that does not require two
additional records.
Marty Kraimer
- Re: calc record question Paul Sichta
- calc record question Maren Purves
Virus Found in message "Paris Hilton, pure!" hostmaster
Re: command to set IOC time Marty Kraimer
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
