1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbpf before iocInit...
To: Emmanuel Mayssat <[email protected]>
Cc: "Allison, Stephanie" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 09 Mar 2005 09:04:59 +0100
Hi Emmanuel,
It's probably even much simpler than that.
As you found out, dbpf() is part of the *runtime database access library*, which works only at runtime (properly locking the record to avoid interfering with the regular processing of records). As the locks are set up during IOCinit, using dbpf() at database load time will fail.
If you want to change field values of records before IOCinit, nothing keeps you from setting the additional fields in the plain regular fashion from a db file that gets instantiated in a later call to dbLoadRecords(). It is perfectly legal to have the same record appear in more than one instantiation step. (It might not be explicitly mentioned in the doc that this is legal, but I learned that many installations use this feature.)
Let me give you an example:
You may load a record in first.db like this:
record(ai,"record1") {
  field(DOL,".5")
and then overwrite/add fields in second.db (which is loaded further down):
record(ai,"record2") {
  field(DOL,"300")
  field(FLNK,"record2")
Most simple, obvious, straightforward, exactly what you want.
On-line adding and deleting records (after IOCinit) is not an easy thing to do and not supported at the moment. It has been on wish lists for a while and might get implemented in the next major version of EPICS. Call again in two years ... ;-)
Cheers,
Ralph
Allison, Stephanie wrote:
So, immediately in the block/template instanciate(record2), I insert dbpf("record1.FLNK","record2").
Part of our IOC startup is to restore values before iocInit using static database utilities. I don't know of any iocsh entries for dbStatic routines. You can write a little utility that does something like this:
#include "dbAccess.h"
#include "dbStaticLib.h"
#include "errlog.h"
long dbpfStatic(char *pname,char *pvalue) {
DBENTRY dbentry; int status;
if (!pdbbase) {
errlogPrintf("dbpfStatic: No database loaded\n");
return -1;
dbInitEntry(pdbbase, &dbentry); if (!(status = dbFindRecord(&dbentry, pname))) status = dbPutString(&dbentry, pvalue);
dbFinishEntry(&dbentry);
return status;
Stephanie Allison
Re: dbpf before iocInit... Emmanuel Mayssat
Re: dbpf before iocInit... Benjamin Franksen
RE: dbpf before iocInit... Allison, Stephanie
Prev: Re: PCI CAMAC Highway Driver? Noboru Yamamoto
Next: RE: PCI CAMAC Highway Driver? Graham S Cross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: dbpf before iocInit... Allison, Stephanie
Next: Re: dbpf before iocInit... Emmanuel Mayssat
