1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbpf before iocInit...
To: [email protected]
Date: Wed, 9 Mar 2005 23:18:10 +0100
On Wednesday 09 March 2005 09:04, Ralph Lange wrote:
> If you want to change field values of records before IOCinit, nothing
> keeps you from setting the additional fields in the plain regular
> fashion from a db file that gets instantiated in a later call to
> dbLoadRecords(). It is perfectly legal to have the same record appear in
> more than one instantiation step. (It might not be explicitly mentioned
> in the doc that this is legal, but I learned that many installations use
> this feature.)
There is one pitfall though, that I have been stumbled over: You should take
care that db files with which you are going to override fields in an already
loaded record are not optimized with dbst. Because dbst silently adds
field(DTYP,"Soft Channel") to all records that don't have a DTYP definition.
Ben
RE: dbpf before iocInit... Allison, Stephanie
Re: dbpf before iocInit... Ralph Lange
Prev: Re: dbpf before iocInit... Emmanuel Mayssat
Next: error building base 3.14.7 w/ cygwin 1.5.13-1 Dale L. Brewe
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: [Fwd: Who is using what EPICS version] John Dobbins
