Hi all- I've found the problem... in this document:
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-1/gpibCoreConversion/conversionNotes.html
in the sample code for "init_ai()", the line:
if (parm) {
should be:
if (parm == 0) {
since this routine is called with parm = "pass", and is meant to run during the first pass.
cheers,
Mike
Re: HippoDraw and others Paul F. Kunz
RE: CA Connect rates under RTEMS Feng, Shuchen
<2005>
2025
2026
Re: HippoDraw and others Rowland, J (James)
RE: 3.14.6/asyn/vxi11 crash -- SOLVED Laznovsky, Michael
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
