1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA Connect rates under RTEMS
To: "Feng, Shuchen" <[email protected]>, "Nolan, William" <[email protected]>
Cc: "''[email protected] ' '" <[email protected]>, "''[email protected]' '" <[email protected]>, "''[email protected]' '" <[email protected]>, "''Till Straumann ' '" <[email protected]>
Date: Sat, 26 Mar 2005 16:43:27 -0500
Kate Feng wrote :
>I finally got around to compare the CA connect rate and  catime between
>RTEMS-mvme5500 and vxWorks-mvme5500.  The conclusion is that EPICS/RTEMS
>and EPICS/vxWorks is competitive to each other while tested under the
>same network setup.
My apologies for misspelling.  I meant the catime test showed that
EPICS/RTEMS-mvme5500 and EPICS/vxWorks-mvme5500  are "comparable" to
each other while tested under the same network setup.  They
showed similar performance for 1K channels, but for the 10K channels
case, EPICS/RTEMS-mvme5500 shows higher performance.  The test was
done in a very busy subnet.
Cheers,
Kate
Prev: RE: 3.14.6/asyn/vxi11 crash -- SOLVED Laznovsky, Michael
Next: The later four ports of IP-Octal-232 could not work. ligang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA Connect rates under RTEMS Feng, Shuchen
Next: RE: CA Connect rates under RTEMS Kate Feng
