1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Logarithmic conversion / Breakpoint tabes
To: Gavin Smith <[email protected]>
Cc: [email protected]
Date: Tue, 29 Mar 2005 10:08:45 -0500 (EST)
On Tue, 29 Mar 2005, Gavin Smith wrote:
> I have an Ai record which gets raw data from a pressure (vacuum?) sensor
> measured by the PLC. The raw data ranges from 0 to 256000 and represents
> a Torr of 1e-11 through to 1e-3. I am wanting to convert this into the
> engineering units, but as far as I can see only linear styles of
> conversion are supported.
We have vacuum gauges with similar output. I just use an ai record to get
the voltage from an ADC connected to the gauge. The ai is FLNK'd to a calc
record which computes the value in Torr.
> In addition to inputs, I need to have a couple of Ao's, representing
> maximum allowable pressures, etc.
Perhaps I am misunderstanding you here, but can't you just use the HIGH
and HIHI field of the pressure calc record for this?
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
Logarithmic conversion / Breakpoint tabes Gavin Smith
Prev: Re: The later four ports of IP-Octal-232 could not work. Martin L. Smith
Next: Re: HippoDraw and others Rowland, J (James)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Logarithmic conversion / Breakpoint tabes Gavin Smith
Next: Re: Logarithmic conversion / Breakpoint tabes Rolf Keitel
