Hi Pete,
We have support for the TSP function in the MPC using RS232.
It is included in the "ip" application in recent versions of the
"synApps" package.
http://www.aps.anl.gov/aod/bcda/synApps/ip/ip.html
The R2-4 release for EPICS 3.14.7, which uses "asyn 4-1" is available
now.
The R2-5 release for EPICS 3.14.7, which uses "asyn 4-2-1" will be
available next week.
Note that the required modules lists "ipac", but that is only if you
want to use the SBS IP-Octal serial module. These releases will work
with any serial port that asyn supports, which includes local serial
ports on vxWorks, Windows, Linux and Unix, and TCP/IP terminal servers
on all platforms.
Mark Rivers
-----Original Message-----
Sent: Wednesday, March 30, 2005 10:48 AM
To: [email protected]
Subject: Digitel MPC - TSP - RS232 Interface
Has anyone out there used the Digitel MPC RS232 interface
to control the TSP functionality?
I have no problem with any of the ion pump commands,
but confusing things are happening when I try to
control the TSP - and in particular set it to timed mode.
(hex command 27)
Pete
Digitel MPC - TSP - RS232 Interface Owens, PH (Peter)
Re: Logarithmic conversion / Breakpoint tabes Rolf Keitel
<2005>
2025
2026
calcout ODLY field Geoff Savage
<2005>
2025
2026
