1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building libraries from only objs and libs in 3.14
To: Janet Anderson <[email protected]>
Cc: [email protected]
Date: Fri, 8 Apr 2005 12:03:01 +0200
On Wednesday 06 April 2005 21:54, you wrote:
> Benjamin Franksen wrote:
> > I have created the example application with
> > makeBaseApp.pl -t example ex
> > When I comment out all the *_SRCS definitions in
> > exApp/src/Makefile, I get
> > make[1]: *** No rule to make target `ex.o', needed by `ex'.  Stop.
> > make: *** [install.hpux-parisc] Error 2
> You should be able to bundle objects and libraries into a new library
> or prod, but you need to have at least 1 source or object defined for
> that LIBRARY or PROD for each target arch.
Hi Janet,
it seems I missed some of the fine print in the docs. This works:
PROD_IOC = ex
ex_SRCS_vxWorks += -nil-
ex_SRCS_DEFAULT += exMain.cpp
ex_LIBS += $(EPICS_BASE_IOC_LIBS)
ex_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
There are some issues here, that are not obvious for the newcomer:
(1) The first is that one needs at least one object or source for a
'product', plus the trick with the "-nil-" definition. I finally found
the place where this is documented, lost among the 30 or so pages of
somewhat repetitive listings of make variable explanations.
(2) Even for vxWorks the final IOC target is an executable (PROD_xxx),
not a library (LIBRARY_xxx) as it used to be. Creating a library for an
IOC ('LIBRARY_IOC...') is completely optional. BTW, I wonder what these
'munch' files are about? Is there a place where I can read more about
them?
> Re-adding the ex_SRCS_DEFAULT += exMain.cpp line worked for me.
> You must have changed something else in the Makefile to stop the
> build of libxxxSupport library. That library is required for the
> ex prod ( ex_LIBS += xxxSupport ).
Yes, but the error says 'no rule to make target xxxSupport.a'. I created
everything again to make sure. Same error. However, since I now
realized that I don't need to create a library, everything is fine for
me (for the moment ;-).
FYI, I attached the latest revision of my additions to our local
configure/RULES which fixes db file generation from substitution files
written in the dbLoadTemplate style. (Please ignore the last include
line.)
Ben
include $(EPICS_BASE)/configure/RULES
DBFLAGS += -I$(COMMON_DIR)
$(COMMON_DIR)/%.template: ../%.template
	@$(RM) $@
	@$(CP) $< $@
$(COMMON_DIR)/%.db$(RAW)$(DEP): %.substitutions
	@$(PERL) -e 'undef $$/; $$_=<>; @d=m/(?:^|})\s*file\s+([^{\s]*)\s*\{/g; map\
	 {$$_="$(COMMON_DIR)/$$_"} @d; print "$(COMMON_DIR)/$*.db$(RAW): @d\n";' $< > $@
$(COMMON_DIR)/%.db$(RAW): %.substitutions
	@echo "Inflating database from $<"
	@$(RM) $@
	$(MSI) $(DBFLAGS) -S$< $(TEMPLATE_FILENAME) > msi.tmp
	@$(MV) msi.tmp $@
ifeq '$(DB_OPT)' 'YES'
DBST_TARGETS = $(addprefix $(COMMON_DIR)/,$(notdir $(filter %.db, $(DB))))
$(DBST_TARGETS): $(COMMON_DIR)/%.db: $(COMMON_DIR)/$(DBDNAME) $(COMMON_DIR)/%.db$(RAW)
	@echo "Optimizing database $@"
	@$(RM) $@
	@$(DBST) $^ -w0,,$@
endif
include $(TOP)/configure/RULES_FOREIGN
building libraries from only objs and libs in 3.14 Benjamin Franksen
Prev: Re: ???registrar(function_name) Andrew Johnson
Next: Re: ???registrar(function_name) Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: building libraries from only objs and libs in 3.14 Benjamin Franksen
Next: synApps 5.1 release Tim Mooney
