1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Possible bug in taskwd
To: "'EPICS Tech Talk'" <[email protected]>
Date: Thu, 14 Apr 2005 09:23:48 -0400
On Apr 13, 2005, at 18:32, Thompson, David H. wrote:
As I understand it, taskwd, is supposed to monitor registered tasks so that when one of them gets unexpectedly into a suspended state some action can be taken.  In our case, taskwd was suspended and no other task appeared in the list as suspended.  Looking at source code, I see that on vxWorks the taskwd main loop calls epicsThreadIsSuspended() which in turn calls taskIsSuspended() in the vxWorks kernel.  Looking there, to see if there might be a cause for the bus error, I noticed that the logic of the routine might not match the semantics that the taskwd is expecting.
Here is the problem, if the task is suspended, the function returns TRUE to taskwd, if the task is not suspended or is non-existent, deleted,  the function returns FALSE.
Seems to me that taskwd would want to know the difference between “running” and “dead”.  Maybe the loss of connectivity lies in a dead task that no longer shows up in the task list.
To the defense of taskwd: In Theory, a task that registers with taskwd should be either running - in which case all is fine, or suspended - in which case taskIsSuspended() == TRUE and taskwd can print a message.
If a monitored task decides to exit, it's supposed
to remove its registration with taskwd.
In Reality, however, we can run into a case where
a monitored task quits because of a problem without
properly un-registering.
Unclear to me how bullet-proof taskwd must be to handle all eventualities:
Check if a registered task ID is still valid, still running,
still associated with the task that originally registered
- since that one might have quit and now we're looking at
a completely different task that just happens to have the same ID?
Bottom line is that taskwd works best when you only write
perfect code that never requires the help of a task watchdog ;-)
-Kay
Re: Possible bug in taskwd Hoff, Lawrence
Possible bug in taskwd Thompson, David H.
Prev: RE: CA; ca_context_destoy and CA channels Liyu, Andrei
Next: Re: Possible bug in taskwd Hoff, Lawrence
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Possible bug in taskwd Thompson, David H.
