1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Possible bug in taskwd
To: "'EPICS Tech Talk'" <[email protected]>
Date: Thu, 14 Apr 2005 10:35:48 -0400
To play devil's advocate........
	Does anyone know what happens in VxWorks
if the C++ "new" operator throws an unhandled exception
if there is insufficient heap space?
	*If* it suspends the task, then taskwd will work
in an intuitive fashion. *If*, however, the task exits,
then (it sounds like) it will escape the notice of taskwd.
	In the latter case, or in any case where a library
function might call "exit()", then taskwd ought to check for
a missing task and treat it the same as a suspended task.
	Alternatively, all code under taskwd supervision
must handle all exceptions, and never use library functions
which might call "exit" (a fairly tall order).
	As Kay says, if a monitored task *decides* to exit,
it should intentionally unregister itself. Under those rules,
there seems little harm in taskwd checking for missing tasks
as well as suspended tasks (as Dave T. suggested).
-- Larry
P.S. I now know the answer to my hypothetical, at least for
the SNS VxWorks kernel. The task is suspended (so taskwd works
properly). Try this code to see what happens in your O/S:
#include <ostream.h> // cout
extern "C" void newTest(void){
  // ask for too much memory
  char *tooBig = new char[(1<<24)];
  // do we get here?
  cout << "Value of tooBig is: " << (unsigned long) tooBig << endl;
RE: Possible bug in taskwd Jeff Hill
Re: Possible bug in taskwd Kay-Uwe Kasemir
Prev: Re: Possible bug in taskwd Kay-Uwe Kasemir
Next: RE: Possible bug in taskwd Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
