1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: SNC SEQ Versions mismatch
To: "Hasan, S.M. S." <[email protected]>, <[email protected]>
Date: Wed, 27 Apr 2005 17:00:04 -0500
Hi Hasan,
> I'm new in EPICS. I tried to write a sequence program.
> Everything worked fine but when i wanted to load the sequence
> program from my VxWorks IOC then I'm getting the following
> error messages .....
> seq rftfExample, "user=test"
> SEQ Version 2.0.10: Mon Jan 31 20:22:58 2005
> Illegal magic number in state program.
>  - Possible mismatch between SNC & SEQ versions
>  - Re-compile your program?
> value = 0 = 0x0
Are you using vxWorks, and the vxWorks shell?
If so, then the syntax of the command you need to use is:
seq &rftfExample, "user=test"
i.e. you need the "&" (address-of) operator before the name of the
program.
Prev: SNC SEQ Versions mismatch Hasan, S.M. S.
Next: SNL suffix and preprocessing Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
