1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SNL suffix and preprocessing
To: TECHTALK <[email protected]>
Date: Thu, 28 Apr 2005 15:32:53 +0200
Hi all,
the IOC Application Developper's Guide says that .stt files are preprocessed before they are passed to snc and .st files not. All R3.13 make rules (at least from releases R3.13.2 to R3.13.9) found in RULES.Vx and (at least) in seq-2.0.8 RULES_BUILD do the opposite. They preprocess .st files and not .stt files.
What should be fixed? Documentation or implementation?
What does the last t in stt mean? Template? In that case, it's probably the stt that is supposed to be preprocessed.
Best regards,
Dirk
PS: Note that the .stt rule in R3.13 (at least until R3.13.9) contains two bugs and does not work. The rules in RULES.Unix and RULES.Host have the same bugs but are never used.
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
Prev: RE: SNC SEQ Versions mismatch Mark Rivers
Next: bad UDP msg wtw00992
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: SNL suffix and preprocessing Laznovsky, Michael
