1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: bad UDP msg
To: <[email protected]>, <[email protected]>
Cc: <[email protected]>
Date: Thu, 28 Apr 2005 14:23:33 -0600
Bill,
The UDP server is receiving undecipherable protocol from port
1030 from several different IP addresses (the R3.12 message
prints the source IP address as a hexadecimal 32 bit word which
may need to be byte swapped).
For CA, the fact that the client's UDP port does not vary is odd
as client ports are typically dynamically assigned and would not
be consistent with the source address.
> What if anything might I do to debugg???
o You might have some rogue program that is using CA's ports, but
why from so many different source addresses? Therefore I am
inclined to guess that something else is occurring - probably
packet damage.
o We have seen troubles with corrupt UDP messages in the past if
there is an IOC that has failed its 10/100 auto-negotiation. This
typically occurs (with vxWorks) if the IOC is turned on before
the switch is turned on. If you have the old thin-wire Ethernet
then packet damage might occur because of improper thin-wire
branching causing reflected signals to be summed together
including time delays (phase errors) induced by reflections off
the end of branches.
There are Ethernet and IP level CRC checksums for the purpose of
catching, and discarding bad frames, but they are not
particularly effective if many bits in the frame are damaged. In
that scenario the source address, destination address, source
port, and destination port, might be damaged and the packet might
still pass through the CRC checksum filter.
You are not seeing any errors at the Ethernet level based on
"ifShow" (unless of course your vxWorks interface driver does not
bother to increment the error counters). You might also have a
look at the IP level error counters by typing ipstatShow.
o I sometimes employ sniffer programs like etherfind, tcpdump, or
a standalone packet sniffer to investigate this sort of issue.
You appear to have a corrupt Ethernet broadcast packet based on
the number of systems involved so you might set your sniffer to
filter for Ethernet broadcasts. If you see bogus packet header
fields that might point to corruption.
o You might also try selectively disconnecting portions of your
network, while waiting to see if the corrupt messages stop, to
isolate the sender.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> Sent: Thursday, April 28, 2005 12:04 PM
> To: [email protected]
> Cc: [email protected]
> Subject: bad UDP msg
> Hi,
> I see that this subject in the archives but I am not having
> much luck
> tracking this down.
> A few days back we started seeing (from a window where the alh
> is
> started):
> CAC: post_msg(): Corrupt cmd in msg d00
> ../iocinf.c: bad UDP msg from port=47585 addr=7f000001
> Of coures any window that opens an medm also shows the message:
> CAC: Undecipherable UDP message from 127.0.0.1:47615
> CAC: Undecipherable ( bad msg code 3328 ) UDP message from
> 127.0.0.1:47615
> at Thu Apr 28 2005 13:10:25
>   (of course the 127.0.0.1:47615 47615 is dynamicly assigned..
> so 47615
> varies)
> A telnet to some (not all) of the processors shows:
> ../iocinf.c: bad UDP msg from port=1030 addr=82c73cc1
> iocLogtext shows
> vtpc2.starp.bnl.gov Thu Apr 28 13:32:23 2005 ../iocinf.c: bad
> UDP msg from
> port=1030 addr=82c73cbe
> vtpc5.starp.bnl.gov Thu Apr 28 13:32:23 2005 ../iocinf.c: bad
> UDP msg from
> stargate.starp.bnl.gov Thu Apr 28 13:32:23 2005 ../iocinf.c:
> bad UDP msg
> from port=1030 addr=82c73d30
> vtpc7.starp.bnl.gov Thu Apr 28 13:32:23 2005 ../iocinf.c: bad
> UDP msg from
> port=1030 addr=82c73d4e
> vtpc4.starp.bnl.gov Thu Apr 28 13:32:23 2005 ../iocinf.c: bad
> UDP msg from
> port=1030 addr=82c73cc0
> creighton5.starp.bnl.gov Thu Apr 28 13:32:23 2005 ../iocinf.c:
> bad UDP msg
> from port=1030 addr=82c73ce5
> one processor gives this on port=1029
> several others on 1031
> and one on both 1031 and 1032.
> For this processor
>   -> ifShow
> ei (unit number 0):
>       Flags: (0x63) UP BROADCAST ARP RUNNING
>       Internet address: 130.199.60.188
>       Broadcast address: 130.199.61.255
>       Netmask 0xffff0000 Subnetmask 0xfffffe00
>       Ethernet address is 08:00:3e:28:f1:f5
>       Metric is 0
>       Maximum Transfer Unit size is 1500
>       3758343 packets received; 1173400 packets sent
>       0 input errors; 0 output errors
>       5579 collisions
> lo (unit number 0):
>       Flags: (0x69) UP LOOPBACK ARP RUNNING
>       Internet address: 127.0.0.1
>       Netmask 0xff000000 Subnetmask 0xff000000
>       Metric is 0
>       Maximum Transfer Unit size is 4096
>       433567 packets received; 433567 packets sent
>       0 collisions
> value = 18 = 0x12
> inetstatShow
> Active Internet connections (including servers)
> PCB      Proto Recv-Q Send-Q  Local Address      Foreign
> Address
> (state)
> f8860c   TCP        0      0  130.199.60.188.506
> 130.199.60.238.526
> ESTABLISHED
> cb688c   TCP        0      0  130.199.60.188.23
> 130.199.60.27.4141
> ESTABLISHED
> fb710c   TCP        0      0  130.199.60.188.506
> 130.199.60.27.4022
> ESTABLISHED
> fb640c   TCP        0      0  130.199.60.188.506
> 130.199.60.27.6085
> ESTABLISHED
> cc858c   TCP        0      0  130.199.60.188.103
> 130.199.61.48.5064
> ESTABLISHED
> f8858c   TCP        0      0  130.199.60.188.506
> 130.199.60.27.6085
> ESTABLISHED
> fb5e8c   TCP        0      0  0.0.0.0.5064       0.0.0.0.0
> LISTEN
> fb650c   TCP        0      0  130.199.60.188.103
> 130.199.60.27.7004
> CLOSE_WAIT
> fb688c   TCP        0      0  0.0.0.0.111        0.0.0.0.0
> LISTEN
> fb6c8c   TCP        0      0  0.0.0.0.21         0.0.0.0.0
> LISTEN
> fb6a0c   TCP        0      0  0.0.0.0.1008       0.0.0.0.0
> LISTEN
> fb6b0c   TCP        0      0  0.0.0.0.23         0.0.0.0.0
> LISTEN
> fb6c0c   TCP        0      0  0.0.0.0.513        0.0.0.0.0
> LISTEN
> cb670c   UDP        0      0  0.0.0.0.978        0.0.0.0.0
> fb610c   UDP        0      0  0.0.0.0.980        0.0.0.0.0
> fb608c   UDP        0      0  0.0.0.0.982        0.0.0.0.0
> fb678c   UDP        0      0  130.199.60.188.103
> 130.199.60.188.103
> f8850c   UDP        0      0  130.199.60.188.103
> 130.199.60.188.102
> cc838c   UDP        0      0  0.0.0.0.1030       0.0.0.0.0
> fb630c   UDP        0      0  0.0.0.0.1029       0.0.0.0.0
> fb658c   UDP        0      0  0.0.0.0.5064       0.0.0.0.0
> fb660c   UDP        0      0  0.0.0.0.5065       0.0.0.0.0
> f8818c   UDP        0      0  0.0.0.0.1028       0.0.0.0.0
> fb5d8c   UDP        0      0  0.0.0.0.1027       0.0.0.0.0
> f8870c   UDP        0      0  0.0.0.0.1026       0.0.0.0.0
> fb6d0c   UDP        0      0  0.0.0.0.111        0.0.0.0.0
> value = 1 = 0x1
> Another processor suspicously (?) shows
> ifShow
> ei (unit number 0):
>       Internet address: 130.199.60.193
>       Ethernet address is 08:00:3e:28:ed:fa
>       Metric is 0
>       3192815 packets received; 233539 packets sent
>       4 input errors; 0 output errors
>       1667 collisions
> lo (unit number 0):
>       Metric is 0
>       168135 packets received; 168135 packets sent
>       0 collisions
> value = 18 = 0x12
> inetstatShow
> Address
> (state)
> a2fc0c   TCP        0      0  130.199.60.193.506
> 130.199.60.27.4021
> ESTABLISHED
> fb620c   TCP        0      0  130.199.60.193.506
> 130.199.60.27.3368
> ESTABLISHED
> f6258c   TCP        0      0  130.199.60.193.506
> 130.199.61.48.1038
> ESTABLISHED
> fb610c   TCP        0      0  130.199.60.193.506
> 130.199.60.159.264
> ESTABLISHED
> f6368c   TCP        0      0  130.199.60.193.506
> 130.199.60.27.5899
> ESTABLISHED
> f6240c   TCP        0      0  130.199.60.193.506
> 130.199.60.27.5898
> ESTABLISHED
> f5f58c   TCP        0      0  0.0.0.0.5064       0.0.0.0.0
> LISTEN
> f6358c   TCP        0      0  130.199.60.193.103
> 130.199.60.27.7004
> CLOSE_WAIT
> LISTEN
> LISTEN
> LISTEN
> LISTEN
> LISTEN
> a2fd0c   UDP        0      0  0.0.0.0.926        0.0.0.0.0
> fb668c   UDP        0      0  0.0.0.0.928        0.0.0.0.0
> f6228c   UDP        0      0  0.0.0.0.930        0.0.0.0.0
> fb690c   UDP        0      0  0.0.0.0.932        0.0.0.0.0
> a2fe0c   UDP        0      0  0.0.0.0.934        0.0.0.0.0
> f6248c   UDP        0      0  0.0.0.0.936        0.0.0.0.0
> a0b80c   UDP        0      0  0.0.0.0.938        0.0.0.0.0
> f5f38c   UDP        0      0  0.0.0.0.940        0.0.0.0.0
> f5f20c   UDP        0      0  0.0.0.0.942        0.0.0.0.0
> fb648c   UDP        0      0  0.0.0.0.944        0.0.0.0.0
> f6348c   UDP        0      0  0.0.0.0.946        0.0.0.0.0
> f60d8c   UDP        0      0  0.0.0.0.948        0.0.0.0.0
> fb658c   UDP        0      0  0.0.0.0.950        0.0.0.0.0
> fb6e8c   UDP        0      0  130.199.60.193.103
> 130.199.60.193.102
> f5f50c   UDP        0      0  0.0.0.0.1029       0.0.0.0.0
> f60c0c   UDP        0      0  0.0.0.0.5064       0.0.0.0.0
> f5f40c   UDP        0      0  0.0.0.0.5065       0.0.0.0.0
> f60c8c   UDP        0      0  0.0.0.0.1028       0.0.0.0.0
> f60b8c   UDP        0      0  0.0.0.0.1027       0.0.0.0.0
> fb638c   UDP        0      0  0.0.0.0.1026       0.0.0.0.0
> value = 1 = 0x1
> So I have rebooted the host, and also many of the processors.
> We are
> running and I wont have a long access to these processors or
> the terminal
> server for a few days.  What if anything might I do to
debugg???
> Note this is old epics  3.12.. and I also dont have caSnooper
> etc..
> These messages are only annoying right now, as they dont seem
> to have any
> effect on our controls.
> Right now only I loose sleep over this!
> I greatly appreciate any advice or suggestions.
> Thanks,
> Bill Waggoner
> STAR
> Creighton University
> BNL
> [email protected]
RE: bad UDP msg wtw00992
Prev: RE: SNL suffix and preprocessing Laznovsky, Michael
Next: RE: SNL suffix and preprocessing Redman, Russell O.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: bad UDP msg wtw00992
Next: RE: bad UDP msg wtw00992
